Thread: Door Pins (Fitting)
    Regular Member Lee..'s Avatar
    May 2007
    Chesterfield
    Default Door Pins (Fitting)
    Anybody ever replaced door pins on a Vectra? How easy are they to do?
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    as far as I am aware they just pull off....push the new ones on, can anyone confirm ?
    not quite....
    get a small screwdriver and prise out the red segment on the VX pin, that will release the shaft and let the door pin pull up and off..
    then using an allen key, tighten your new alloy pins back on to the steel rod at the height you want them to be at
    Jul 2006
    Absolute doddle m8 less than 10 mins to do all 4.
    Get a tiny screwdriver and prise the red clips out of the original pins, then the plastic pin just lifts off.
    You're left with a metal stalk.
    Put the new pin on the stalk and tighten the grub screws to secure. Lock door to check the position of the pin. Adjust if necessary.
    Stand back and admire
    Edit: beaten by the spannergod
    Feb 2007
    Glasgow
    Chester
    As above. Piece of ****. Even I can do it. You may have to chop the rear ones down a bit as the rod is at an angle which means they sit higher than the fronts ones.
    Only if it bothers you obviously.
    May 2007
    Chesterfield
    Thanks all
    Jul 2006
    Quote Originally Posted by Stevel View Post
    Or just adjust the front ones to the same level... No sawing (and therefore resulting damage of internal trim in my case) involved
    Chester
    Quote Originally Posted by parapaul View Post
    They sat too high in mine. For my liking anyway. I trimmed the actual pins in the garage so no chance of damaging the trim.
    [Ex]Admin Duncan's Avatar
    And if you're a bit of a perfectionist and don't want the grub screws showing - http://www.vectra-c.com/forum/showthread.php?t=20081
  1. Richbrook Door pins fitting problem.
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 10:36
  2. New door pins, fitting help
    By Andy17899 in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 00:34
  3. Door Pins - Will these fit my car?
    By sduk in forum Styling
    Last Post: 31st July 2008, 20:59
  4. Fitting door pins
    By Baz07 in forum Bodywork & Interior
    Last Post: 20th April 2008, 21:18
  5. Door Pins Again ...
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2006, 22:59
