Results 1 to 10 of 13
Thread: juddering when pulling off.
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Default juddering when pulling off.
    hi, the car has just started to judder when pulling off. it is worse wneh cold.
    any ideas or thoughts would be appreciated. thanks
    Regular Member Loines19's Avatar
    Leicester
    Sounds like clutch bounce! What engine is it? How many miles it done?
    Sorry, read the title wrong!!!!!!
    Nov 2007
    LEICESTERSHIRE
    Quote Originally Posted by Loines19 View Post
    1.8 21000.
    Leicester
    It sound harsh but try pulling off at high revs, slipping the clutch. Sometimes the plates become too stickey this helps smooth and clean them off. Failing that back to the dealer under warentey!!
    Where abouts in leicester you from?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by VEC-MAN View Post
    1.8 21000.
    Common fault on the 1.8 VVT, DMF fault, warranty fix, ask Mark, he knows the details, i've seen him mention this problem before.
    Nov 2007
    LEICESTERSHIRE
    hinckley
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Seriously, wasn't there a clutch issue on some 1.8's????????
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Duel Mass Flywheel
    Regular Member mat osborn's Avatar
    Jan 2008
    leicester
    I had same fault 1.8 at 34000 miles dealer replaced flywheel and clutch on warranty common fault dont let them fob you off like they tried with me mine was done at drive freemans common and took a day to complete
  1. Pulling to the right.
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 23:41
  2. Car pulling to the right :(
    By !tf in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 19:18
  3. Juddering When Pulling Away??
    By MHowVECSRI07 in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 16:57
  4. car pulling in 2nd
    By Morephun in forum Engine & Drivetrain
    Last Post: 18th February 2009, 02:12
  5. Pulling Out Of The Pod...
    By Mark The Cabby in forum General Chat
    Last Post: 6th June 2006, 23:14
