Thread: please help
    luton
    Default please help
    hi all just wanted to pick your brains really , i have just noticed when i turn the steering wheel it some times goes heavy for about a second then back to normal . it only happens when i corner hard but is quite worrying. has anyone else had this and do u no what the problem is (please dont say the pump) cheers all.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    could well be the pump i,m afraid...........have you cked the fluid level
    luton
    not yet just found the tank tucked right down under the light so suppose ill have to take the bumper off to get to it
    Here, there and every where!
    Yup, bumper off job just to check the fluid level i'm afraid
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Default juddering at pull off ????
    the car as just started to judder when pulling off. i notice it is alot worse when cold.
    any ideas would or thoughts would be appreciated.
    Last edited by VEC-MAN; 13th August 2008 at 21:24. Reason: this should be a new thread. sorry.
