Thread: Axle weight?
    Sheffield
    Question Axle weight?
    Hi all,
    Which of the 4 weights listed on my VIN sticker in the door pillar are which?
    From top to bottom, it reads:
    2145
    3745
    1-1120
    2-1060
    Tried to order some eibach springs from roadrunner, but none of the ones he had listed seemed to match??
    Got a Siggy 1.9 Elegance CDti 150
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    In your order listed.
    1. Gross Vehicle Weight Indicates maximum legal laden mass, in territories where this is required
    2. Gross (Max permissible) Train Mass Indicates the maximum combined mass of vehicle and trailer or caravan
    3. Permitted Front Axle Loading Maximum permissible load on the front wheels of the vehicle
    4. Permitted Rear Axle Loading Maximum permissible load on the rear wheels of the vehicle
    Full Member Big Sig's Avatar
    Sheffield
    Thanks guys,
    This still doesn't seem to marry up with the options they have listed though?:
    Car Front Rear
    Signum 1.8, 2.0 Turbo, 2.2, 3.2, 2.2 DTi 03.03 - 1060 kg 1140 kg
    Signum 2.0 Turbo, 3.2, 2.0 DTI, 2.2 DTi 03.03 - 1130 kg 1140 kg
    Signum 3.0 l DTI 05.03 - 1230 kg 1140 kg
    And the guy on the phone was saying the rears are 1080???
    Jul 2006
    The spring weights listed are 'up to' values - all Eibach springs have the rear value of up to 1080kg. And what they've told you isn't right, the ranges are
    1. Up to 1060kg
    2. 1061 to 1130kg
    3. 1131 to 1230kg
    You need the second of those options, front axle weight 1061 to 1130kg
    HTH
    Sheffield
    Sorted - thanks. Springs on order from LMF (along with BSR and K&N)
    Here, there and every where!
    Let the mods begin
  1. 2.8T V6 Axle Weight
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 10:23
  2. axle weight plate?
    By tonyblade in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2009, 17:05
  3. axle weight
    By chelskilee in forum Handling & Braking
    Last Post: 23rd February 2009, 20:53
  4. Front axle weight
    By LOCKSTOCK in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2008, 21:33
  5. axle weight ?
    By JOE DTI in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2006, 17:41
