Thread: New Brakes Required
    Winteringham
    Default New Brakes Required
    I need to replace front and rear pads and disks on my 2005 Vectra Elite 1.9CDTI, I've been quoted £400 by dealers and £400 by quick-fit both fitting standard spec disks and pads I can get EBC drilled and grooved with green stuff pads for £375.
    just wondering is it worth while doing a big brake upgrade and what the cost are going to be or does anybody else recommend different pads and disks?
    you can't beat the big brake upgrade from LMF, but it ain't cheap at £300+...
    those prices BTW are a ripoff.. both VX and kwakfit will pay under £100 for all the parts, so they are charging you £300 for an hours work...
    Winteringham
    looked at the lmf option but they don't list rear pads, do they sell them?
    Regular Member smokydiesel's Avatar
    barnsley
    Thumbs up
    try auto-vaux for the brakes i replaced mine on the veccy b i put 308mm disks and calipers on the front you need a different hangers to move the calipers out i have mintex pads all round the disks are mintex i drilled them up myself
    i was told the disks on the 1.9 cdti 150 should be running 308 mm disks but when i checked mine they are 288 mm, when the time comes bigger is always better so the missus says
    Jul 2006
    Quote Originally Posted by carteg View Post
    You bet they do
    Make sure you ask for the disc & pad sets, price is £65 + VAT per axle set, less if they give you a discount. So under £200 for your parts, and any garage will be able to change the lot in under an hour.
    Winteringham
    fitting not a problem can do that myself just want to make sure i'm getting the right brakes and pads
    Jul 2006
    Have a look in the 'Part Numbers' section - there's a thread with the part numbers for each size disc & pad set
    Winteringham
    if I get the 314 upgrade from LMF do i get standard, drilled or 20 groved?
    Winteringham
    Placed order with LMF for the following Parts:
    314mm front brake upgrade
    292mm rear brake upgrade
    rear brake carriers
    and pads all round
    total price £417.27
    just got to wait to get the bits & hopefully they wont get lost in the post
    Winteringham
    Are there any bits I need to get from Vauxhall to make fitting the new brake kits easier?
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Help required please!!!!!
    By Jaz50 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 01:38
  3. Your views required or help required??
    By Colin S in forum Detailing and Car Care Discussion
    Last Post: 18th September 2008, 02:15
  4. Help required
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 01:13
  5. help required plz
    By zander22 in forum Diesel Engine related
    Last Post: 4th June 2007, 01:07
