Thread: Fitting K&N filter?
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Fitting K&N filter?
    had a quick look today at fitting my filter....does the box just come off or do you need to take all the torx screws and the air hose off to get in the damn thing? As far as I can see there is a screw right under the air pipe, so do I need to remove all this before I can change it?
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    Unfortunately you have to remove the air hose and all the torx screws.
    Don't forget the torxscrew under the "air hose" (the 4 inch rubber hose which goes to the air-box)
    damn..thought so...not as easy as I first thought...apart from having to remove the hose, is it simple from then on?...also is the hose and clips easy to get on again once finished?
    It was very straight forward on my CDTi mate. Is the 2.0T much different?
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    really easy to fit on my 1.8...took about half an hour including the air box mod..
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Sorry to be thick...but what's the "airbox mod"?
    Here, there and every where!
    Hemel Hempstead
    Thanks Caterman. Anyone any idea why VX restrict half the airbox?
    Cuts down on the intake noise.. EEC drive-by noise regulations..
    The GSi is noticeably ' rortier' with the small duct section removed.
  1. 24 hours after fitting a K&N Panel Filter
    By davedrinks in forum Petrol Engine related
    Last Post: 9th May 2012, 19:15
  2. Fuel filter fitting/locking
    By justin32 in forum Engine & Drivetrain
    Last Post: 16th December 2011, 03:13
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. Noise on Cdto 150 since Fitting K & N Panel Filter
    By DeanF in forum Diesel Engine related
    Last Post: 28th September 2010, 21:57
