Results 1 to 10 of 15
Thread: What should i do??
    Regular Member sberrow's Avatar
    Newport (Gwent)
    confused What should i do??
    Ive had new body kit, Spray Job, new wheels and tints done. now i have turned to the engine. I have a K n N Filter fitted, a full stainless system inc sports cat off the turbo. was told by the exhaust ppl to have it re mapped, Thought of getting 'superchips' to do this but i do want to get the most out of the engine. thought of new leads, boost valve etc. I dont know much about engine and what ive had done was on the advice of others. could anyone help?? What do you advise????
    Car is a 2004 ~ 2.0Turbo
    Regular Member shan's Avatar
    Sounds like you need to talk to BSR.
    Newport (Gwent)
    PPC Tuning System 2.0T - Pre Facelift to MY 05 Vauxhall / Opel Signum 2.0T - Pre Facelift to MY 05 (175BHP / 261NM)
    • Tune your car in minutes
    • No mechanical operations needed
    • 16% increase in BHP to 204BHP
    • 19% increase in Torque to 310NM
    • Updates via the internet free of charge
    • All BSR tuning software included
    Increased Mpg through more economical use of fuel
    • Change between tuned settings and original settings at a touch of button (Simply plug the ppc into the diagnostic outlet and press the button)
    Available for most turbo engines both petrol and diesel
    BSR PPC2 programming unit
    BSR is a leading Swedish supplier of Vauxhall / Opel performance and tuning upgrades that enhance the potential of the Vauxhall / Opel engine to provide increased performance without sacrificing normal drivability.
    Market Leading Tuning Software
    PPC is supplied with a highly developed and sophistocated tuning software from BSR. the software optimises all engine parameters such as ignition point, fuel, boost pressure etc.
    The software is developed for each engine type and is tested carefully with most advanced equipment available. This will guarantee the best performance, durability and fuel economy. BSR tuning software also complies with current emissions requirements.
    The power and performance is well documented and often 'best in test', which confirms that BSR leads the development of tuning software for newer car models and control systems.
    We recommend a K&N Panel filter for maximum performance
    Note: You must supply vehicle chassis number at time of ordering.
    0% Details Part Number:SKU17953Price inc VAT:£558.13 Shipping costs:£10.00Options
    Add to cart Add to wish list
    Newport (Gwent)
    Cheers mate. spoke to superchips, and i think im going to go with them, and leave it how it is, new plugs, leads, chip, re~map, boost valve
    I would think you will see more than 204 bhp with the BSR with the stuff you have allready done.
    What are superchips saying you will get ?
    Newport (Gwent)
    36bhp the chip they recon 230+ total
    Newport (Gwent)
    depends on what boost they run
    first off.. no leads on a 2.0T...it's got coilpacks..
    no boost valve.. it's a different setup to the 'old' VX's..
    Get the BSR... with those mods you're going to be looking at a reliable 230BHP and it's well tested and trusted by folks on here..
    Here, there and every where!
    .....and don't forget, if your car happens to go back to the dealers and the flash the ECU then your remap has gone
    With the BSR it won't happen
