Results 1 to 2 of 2
Thread: Vectra 1.9 CDTI SRI Nav Misfire??
    London
    Default Vectra 1.9 CDTI SRI Nav Misfire??
    Hi there,
    Just driving into work this morning and seemingly from nowhere a car with a spanner light appears on my dash and the engine starts to jerk and I experienced a loss of drive. This was at around 40 mph in 4th gear doing around 2000 rpm.
    The light goes on and off and the engine shudders when it goes over 2000rpm or when I try to accelerate in too low a gear.
    The car runs perfectly in idle or if I change into next gear before going over 2000rpm...
    I have booked it into a garage tomorrow morning.
    Can anyone here offer me some wisdom ahead of this to give me some ideas as to what the problem is, if its a known issue with this model, and how much it is likely to cost to repain in parts and labour?
    Thanks and really appreciate your help.
    J
    as per your other post, it does sound like it could be the swirl valves... if it was the faulty injector wiring issue then it would run on 3 cylinders at idle..not just at 2000 rpm..
  1. Misfire 1.9 cdti 120
    By matt2002 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 08:38
  2. misfire on a 150 cdti- help pls
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 11:21
  3. Vectra 1.9 CDTI SRI Nav Engine Misfire issue
    By Joe1 in forum Engine & Drivetrain
    Last Post: 16th September 2009, 10:14
  4. 1.9 CDTi MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 19th March 2009, 23:28
  5. 1.9 cdti misfire
    By johnboycdti in forum Engine & Drivetrain
    Last Post: 10th March 2007, 10:37
vauxhall vectra 1.9 cdti sri misfaring
vectra c 1.9 sri misfiring
vectra c running at 40 mph
