Thread: 5th & 6th gear
    Regular Member dean_walsh2001's Avatar
    swansea
    Default 5th & 6th gear
    When im driving at 60/70/80 MPH the steering wheel shakes abit in 5th but is alot worse in 6th gear. I've had them balanced, tracked etc but still the same.
    Does anyone know what could cause this?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Could have a buckled wheel or track rods ends need replacing
    Yorkshire
    Could it be a more of a vibration that varies slighty depending on how much throttle you have on? if so it could be the dual mass flywheel
    swansea
    Quote Originally Posted by m0cea View Post
    thanks mate i hope it aint the dmf the cars only done 2k lol
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
