Thread: Brake probs
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Default Brake probs
    i keep getting the ABS and T/c lights coming on the dash with the ocassional lumpyness in the pedal as though the ABS wants to kick in ???? the lights go off when the ignition is turned off , 52 plate 2.0 DTI Elite
    Jul 2006
    Mexico
    Guess the best way to go mate is get the codes read.
    Could be a fault on the ABS unit.
    On the other hand...have you checked the level on the brake fluid?
    checked the sensor lead for chafing Steve?.. sounds like it's getting a bad signal from somewhere.. check the underwing connectors too..
    Apr 2006
    Wigan
    Tech 2 says road wheel speed sensor fault (low voltage ) were's this sensor located , confussed
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Take the wheel off on that corner, you will see the speed ring (with 'castelations', on and off) on the back of the hub area and a sensor in close proximity. Firstly, check for wire / connector damage and security.
    Apr 2006
    Wigan
    cheers Ste
  1. 150 probs
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 22:54
  2. Weird brake/clutch probs..
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 17:19
  3. Few probs :)
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 20:42
  4. A few probs..
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2008, 15:28
  5. big probs
    By dextrovix in forum Engine & Drivetrain
    Last Post: 30th November 2006, 08:10
