Results 1 to 10 of 17
Thread: rear brake upgrade
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    Default rear brake upgrade
    i have the std solid discs on the rear and having gone 315mm on the front.. and want to put the vented set up on the rear.
    disc and pad kit i can get trade club .but whats needed to adapt the caliper is it new caipers or hangers to space it out.. any help and part numbers will help,, or has any one done this mod
    Surrey
    The extra 1mm must be rust.
    I too would like to upgrade the rears, for the looks as I understand they don't do much of the work.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    If you are going to do the 292 rear upgrade you will need the discs, the carriers and if you dont have vented discs already on the rears you will need some more calipers or you will need to grind the pads down to fit and also trim the crap guard.
    Oct 2007
    Leicester
    Trim : Elite vxline
    Mileage : 80000
    still need to here from someone whos done the mod see if it worked
    Regular Member shan's Avatar
    Take a look at this thread. The carriers are just wider to accommodate the 20mm wide vented disc rather than the standard carrier being 10mm wide for the solid disc.
    Works perfect.
    PS Good look in finding the carriers as i had to wait 6 weeks for mine to made by Opel in Germany. Non at all in the UK.
    I paid 75 quid for them from LMF
    http://forum.vectra-c.com/showthread.php?t=54277
    Jul 2006
    Several people have done it m8, it's a viable option. The only problem you may have is if you try to fit brand new discs AND pads with the old calipers - they're not quite wide enough.
    If your pads are part worn they should fit OK with the new discs.
    Drop Drinky a PM - he's the man who's done the work so far
    Oct 2007
    Leicester
    Trim : Elite vxline
    Mileage : 80000
    sent him a pm see what he says
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Plasma and I were in the middle of this job on my veccy and you need to take quite a bit off the pads. So im going to purchase a set of calipers as grinding half of the pads away seem a false economy.
    Winteringham
    just placed order with LMF for new rear pads and carriers and vented disks and they said I don't need to take anything off the pads!! were they wrong?
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Yes, they told me the same, when i got the discs and pads from them, unless you have the 2.0T 3.0 or the 3.2 you will need to slim the pads down or get some calipers.
  1. 292mm vented rear brake upgrade...
    By danBoy in forum Parts for sale
    Last Post: 12th September 2010, 21:48
  2. Rear brake upgrade question.
    By John LE in forum Handling & Braking
    Last Post: 9th August 2009, 20:55
  3. 314 Brake upgrade set.
    By tyreman in forum Parts for sale
    Last Post: 1st February 2009, 22:41
  4. 292mm caliper carriers - Rear Brake upgrade
    By parapaul in forum Parts for sale
    Last Post: 28th June 2008, 09:56
  5. big brake upgrade
    By vectra 2.0 t in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2006, 23:06
