Results 1 to 10 of 16
Thread: Driver side door shut but showing open on display
    May 2008
    west midlands
    Default Driver side door shut but showing open on display
    Cannot lock the doors with central locking or with the door button as the door open sign displays even when the door is shut properly. Have checked for clearances and nothing is blocking it or in its way. This is only with the driver's side front door
    Had to shut all doors manually today ...
    Regular Member poves's Avatar
    lancashire
    Have u checked the courtesy light switch pin in the doorframe ?
    May 2008
    west midlands
    where exactly is it on the door frame and does it need to be or can it be switched off/on ?????
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No frame switches, it's inside the lock mechanism.
    Try using a screw driver (or other device) to close the lock on the door to the second latch and see if the icon goes out.
    May 2008
    west midlands
    i can push the lock mechanism latch by hand once and it will click forward but do i need to push it again for the second latch .. ???
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Had a similar problem with mine but with the rear door, took it to dealers as it was still under warranty and it needed a new lock mechanism! While I waited for the part to arrive they disconnected it so I didnt get the light on the dash.
    Sorry that probably doesn't help much!
    May 2008
    west midlands
    tried pushing the lock mechanism on the second latch and the light still didnt go off
    checked it with the rear door and the door icon does go off - so definitely something to do with the lock mechanism -
    Regular Member Loines19's Avatar
    Leicester
    Had the same problem with mine. It was the lock!! Because the drivers door gets used so much more than the other doors it wears it out. Brought a new door lock, which is the motor and lock in one. About £70 new from stealers!! Bit of a pig to fit aswell, would be better to get someone to fit it for you, if not a lot of swearing will be going on!!!! Hope it all works out for ya!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would remove the lock and dismantle it. It's probably something really simple wrong with the switch inside not reporting a closed latch
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Its the catch plate. Do a search, Duncan knows the cure If I remember, you will see little measurements on it, it just needs moving a little.
  1. Rear Driver side door
    By dan21 in forum Bodywork & Interior
    Last Post: 15th January 2013, 14:50
  2. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  3. Driver Door showing as 'Open'
    By lew1984 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th August 2011, 12:30
  4. Replies: 9
    Last Post: 15th October 2010, 17:57
  5. HELP door open display in dash
    By lee in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2007, 01:41
vectra c door light switch www.vectra-c.com
