Results 1 to 10 of 16
Thread: Droning Noise from Wheels - worst at 50mph
    Leicestershire
    Default Droning Noise from Wheels - worst at 50mph
    Morning All,
    I have a 05 plate Vectra 1.9CDti with 40k on the clock.
    The vehicle has developed a droning noise which I think is coming from the front wheels, this is the loudest at 50mph. I dont really notice any handling problems at any speeds.
    I have been reading all about tyres, wheel bearings etc but would like opinions on my particular case.
    I was told via my last service that it has got a noisy wheel bearing...could it be that has got worse?
    The tyres I have on are - Front Michelin, done about 6k miles, original Bridgestone(? - I would check - but its raining!) on the rear.
    Also, any advice on good garages in the LE11 area - the dealship is too expensive!
    Many thanks, Mark
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like the bearing to me mate. Had the same symptoms. You can get the part for about £65 from ebay and a local garage should only charge you 1 hours work, about £40. Bearing is over £100 from dealer so money saved by doing it this way. HTH. Just pop into you local garage and get them to check the bearings and say they can fit it for you. Odds on they wont charge you for for checking them.
    Regular Member poves's Avatar
    lancashire
    Ye I have the same symptoms , Is there a vectra without a droning noise I'm beginning to wonder.
    Me n a mate narrowed it down to the front o/s bearing .
    There is a recall on wheel bearings that applies to some models
    Mine isn't in the range, but VX have decided to replace them all as a warranty claim and monitor
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Don't drive at 50, to avoid the noise, turn up the radio too.
    Leicestershire
    Morning All,
    Thanks for all the replies.
    I had a quieter driver to work this morning as I was stuck behind a lorry so couldnt make it up to 50 mph!
    The car is booked in for a look tomorrow morning so fingers crossed this can all be sorted quite quickly (and cheaply).
    One further question - I have a 4th year warranty, would a wheel bearing be covered by this - I believe the dealership tried to get this work done when the car was in for a swirl valve last month but couldn't as it was only 'noisy'. What do people think?
    One final thing - how safe is it driving with this problem - I do 34 miles a day and this noise has been around for about a week (a lot worse now tho'!).
    Thanks, Mark
    the bearing will just get noisier.. it won't fail and leave you stranded.. just deaf..
    the 4 yr warranty should cover bearings and they really should have changed it last month.. Vectra bearings don't fail and present loads of float at the wheelrim, they just growl and get progressivly louder..Take it back and tell them that it deffo needs changing..
    May 2008
    fife
    how big a job is it to do can you change it urself
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Not that bad mate, straight forward if you have a torque wrench. The only reason I got mine done at a garage was that I couldn't get the Hub nut off, Mark (GSi3.2) said it would be ferkin tight, and he was right, it bent my socket set in half .
    May 2008
    fife
    how do you go about removing it
  1. Droning noise from wheels/brakes area?
    By Thom in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2012, 18:08
  2. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  3. really loud droning at 50mph
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 15th March 2010, 20:04
  4. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  5. droning noise when reversing
    Last Post: 16th March 2009, 08:52
growling sound from 30th vectra
droning noise 50mph
