Thread: Can a moth set off the alarm?
    Regular Member wardy's Avatar
    Chichester
    Default Can a moth set off the alarm?
    Had my alarm go off twice this week for no apparent reason. Tonight it went off & when I went out to the car there was a moth flying around inside (must have opend my wallet.
    Can this be the reason the alarm has been going off? Just wondered if anyone else had this before.
    it can be. if it upset the internal sensor.. other common faults that upset the alarm are door switches and the battery in the sounder unit failing..
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Jet wash once set off my alarm. No idea how.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just looked at your profile to see if you have an estate, OMG that pics not nice Anyway, you do, there seams to be a common problem with the estate alarm. There is a wire running within or on your rear glass (those in the know pls confirm)to cover broken glass. This wire can get damaged and set the alarm off. Have you checked if that is ok? Try setting your alarm with the ultrasonics switched off, if the alarm still goes off your moth is in the clear.
    Yorkshire
    A moth can set your alarm off for sure.
    norn iron
    deffo a moth , no problem. exact same thing happened me a while ago. had me up twice in one night!
  1. Alarm?
    By VikingLammy in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2012, 10:35
  2. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  3. Set alarm
    Last Post: 9th September 2009, 20:15
  4. Moth
    By Sawyer Reynolds in forum The 'Off Topic' room
    Last Post: 27th May 2008, 01:04
  5. Moth
    By ed taylor in forum Comedy & Humour
    Last Post: 6th March 2008, 20:45
