Thread: engine bouncy
    SAUCHIE
    Default engine bouncy
    Hi All.
    Here is a problem with my 05 1.8 vectra. When I am slowing down at roundabouts the engine lunges forward just before I change gear its like something is bliping the throttle open just before I change gear also if I am driving normally and take my foot off the gas the engine bounces. if I am stuck in traffic and I am on and off the gas its hell as the engine bounces every time the foot is lifted off the gas. HELP !!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    At what engine rev, does it happen at any rev or at a particular rev.
    When I have lifted off and decelerating, the engine kicks at 1100 rpm to remind you you're still in gear and to press clutch etc.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Engine mount or driveshaft maybe ?
    SAUCHIE
    the one single blip is about 1100 rpm which normly does it when coming to either a junction or roundabout. I now have to dip the clutch well before I would normally so this does not happen. As for the bouncy engine this does this nearly every time I take my foot off the the throttle. The only way I can stop it from bouncing is to release the throttle very slowly and I mean very slowly this stops the bounce.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    mine does this..and does it when applying the gas have asked lots of questions on here and on other websites and had car 2 times on tech2 and nobdy knows...slow moving traffic is bad
    SAUCHIE
    have you done the air box mod. It made a huge difference to my flat spot.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sounds as if an engine mount has given up. Mine is also 1.8, the kick at 1100 rpm is normal and feels like the old time, engine rev too low and kicking as it getting jumpy. It's to make you de clutch before engine damage occurs from too low rev and some load on it.
    SAUCHIE
    cheers will check al engine mounts and tie rods. Don't know if there is any onther things that can cause it.
  1. Bouncy Rear
    By mon in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2013, 14:31
  2. Bouncy bouncy
    By Nicolas in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2012, 09:47
  3. Bouncy, bouncy, bouncy.
    By kenbo in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2012, 16:10
  4. bouncy car
    By jools in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2007, 10:00
  5. Bouncy Bouncy
    By Stringlabel in forum Handling & Braking
    Last Post: 1st February 2007, 12:33
