Thread: A question for 3.2 gsi : )
    Regular Member poves's Avatar
    lancashire
    Default A question for 3.2 gsi : )
    Hi mate , need your advice on somethin , just replaced oil cooler and what a *****.
    Everythin is back together now , but I have a bit of an idlespeed issue , sometimes it's bang on 750 rpm , and other times it will creep up to the 1000 rpm .
    It never did this before and the only thing I can think is maybe something is clogged like a breather.
    It was very messy and I had to flush the cooling system about ten times to get rid of the gloop.
    I think your the only one who can help , it's doin my head in mate !
    Leighton Buzzard
    Don't think he has seen this, so will point him in your direction tonight
    lancashire
    Thanx
    Jul 2006
    Mexico
    I´m not Mark, and I´m not even close to his mechanical knowledge, but any way .....have you checked the Idle valve itself? Making sure everithing is clean and well connected?.
    HTH
    lancashire
    Quote Originally Posted by BlueRob View Post
    HTH
    Ye I have mate , I used your how 2
    Although I'm now having auto gearbox problems , I can't believe it
    Quote Originally Posted by poves View Post
    Quote Originally Posted by Mrs GSi View Post
    He's seen it..
    check ALL the breather lines...and check for air leaks on the inlet manifold now you've had it off as unmetered air leaking in will let the car rev up slightly without the idle valve being able to control the idle..so check the seals aren't nicked and leaking...that would be my main start as it's about all you have disturbed that could affect the idle speed...
    Jul 2006
    Mexico
    LOL! cool glad that How2 helps.
    lancashire
    Cheers guys
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
