Thread: Eibach springs
    Jun 2007
    northants
    Default Eibach springs
    Hi guys decided to lower my 2.0t design signum at same time as fitting 18s using eibach springs my question is when i checked the weight of the front i read 1-1060 2-1080 well i believe the 1060 is the cut off between 2 kits! well as im on the cut off do i get the lower kit or the higher rated kit? how much lowering does this kit produce i did read that the design had sportier suspension than the rest of range and was lower already?? what im looking for is to lower a bit with a sportier feel to the handling
    Regular Member shan's Avatar
    I'm not sure on this one. I carn't remember what one's i got.
    But if you call roadrunner motorsport they will advise you. Tell them your from vectra-c and they will give you a discount as well I paid 140 quid delivered for mine.
    Here, there and every where!
    On the Signum yes m8, it is the equivalent of the Veccy SRi so will be approx 15mm lower to start with.
    Roadrunner are superb to deal with and will advise you what you want
    i alway err on the higher side, or you can get coilbound springs if they are too soft..
  1. Would these Eibach Springs fit?
    By coldo in forum Suspension, Wheels & Brakes
    Last Post: 25th August 2011, 18:31
  2. Eibach Springs????
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 20:03
  3. Eibach Springs
    By j0shuar in forum Handling & Braking
    Last Post: 15th July 2008, 19:31
  4. Eibach springs
    By topline in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2006, 10:50
