Results 1 to 2 of 2
Thread: CCR2006 cage removal - help please!!!
    Regular Member robster23's Avatar
    Hastings
    Default CCR2006 cage removal - help please!!!
    Hi Guys,
    After searching the forums I learned how to remove my CCR 2006, thanks for the help! But now i've got it out I find that the plugs I want to patch in to for an amp and sub are mounted in a metal cage which I can't remove!
    Has anyone done this? I removed the single screw at the rear of the cage but it looks like i'll have to bend this cage out of shape to prise it out! Surely it can't be this hard!
    Failing that - where do the speaker cables for the rears run to? I want to patch into them!
    All help very very gratefully received.
    Yorkshire
    If you squeeze the top and bottom edges inwards this will pull the sides inwards so you can withdraw the cage. Just bend it back to straighten it out.
    I've done this hundreds of times in my old job!
  1. double din cage
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 23:50
  2. cage
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2010, 23:13
  3. Vectra Diesel fuel filtre removal from bulkhead crash cage
    By Readster in forum Engine & Drivetrain
    Last Post: 23rd November 2008, 23:15
  4. CCR2006 removal help!!!!!
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2007, 16:58
ccr 2006 removal
removing ccr 2006
