Thread: 1.9CDTi EML light on until engine started
    Mar 2007
    Attleborough, Norfolk
    Default 1.9CDTi EML light on until engine started
    Good Morning All
    I had been pumping the tyres for going on holiday, with a 12V electric compressor, and I had to have the ignition turned on to power the cigarette lighter socket. I switched off and disconnected the compressor but later when I went to start the car the "spanner light" came on with the ignition turned on. The engine started, the light went out and the engine appeared to be okay. I went out for a drive and it runs fine, not in limp home, no smoking just driving the same as usual.
    However switching off the engine then turning the ignition back on causes the EML light to come on again until the engine is started. What is this likely to mean? Do I carry on and see what happens, do I get the fault code read or is there something else for me to try?
    I would welcome any advice bearing in mind I'm off on holiday in a few days.
    Thanks.
    Brian
    Feb 2006
    Guttedsville
    The later ones do as a matter of course. If it stays on for a few seconds afterwards and goes out, then it's flagging a fault.
    Totally normal, Don't panic!!
    Mar 2007
    Thinking about things now I'm a little confused. Is the EML indication the light with the big spanner symbol or the engine symbol? What's the difference between the two when faults are displayed?
    Also what should be displayed and where when the Flexi Service due mileage is nearing?
    Thanks again.
    Brian
    INSP is displayed or the car with an oil can symbol when it needs a service...
    if it's a minor fault, then the car and spanner will come on when the key is in posn 2 before you start it..then, when you start it it will go out. This is telling you that there 'was' a fault but that it's now gone.. it's only a real issue if it's permanently alight...
    Mar 2007
    Thank you both for your assistance. As soon as you see a new light come up on the dash you see £££££ signs before your eyes.
    Any idea of how long the spanner light will show in ignition key position two position presuming this not a permanent situation.
    Brian
    Regular Member oil-burner's Avatar
    Jan 2008
    newcastle upon tyne
    it will stay lit like that untill the car has been started a number of times (usually 20-30) or a fault is once again detected. if you have a spare half an hour, sit in the car just starting it up then switching it off. remove the key each time and allow 20 seconds for the car to power down and the imobilizer to kick in. worked for me.
    Mar 2007
    Thanks OB
    I'm up to 20 engine starts since the original fault so I may take your advice and do the rest sitting on the drive.
    Mar 2007
    Good morning all
    The "spanner" light did go out eventually as suggested but it was more than 30 engine starts and 10 days after the problem appeared. I have wondered since if each engine start needed the ignition key taking out and/or a certain time period between each restart?
    Anyway the Vectra is running well again at the moment, having covered over 2000 miles in the last week or so at just above 50mpg average.
    Thanks again for the advice.
    Brian
  1. Started on my engine
    By paullivi in forum Styling
    Last Post: 30th July 2012, 13:18
  2. 1.9CDTI (150) Won't Rev When Started
    By robblue2x in forum Engine & Drivetrain
    Last Post: 26th November 2010, 19:18
  3. 1.9cdti juddering when started
    By mark-1-spark in forum Engine & Drivetrain
    Last Post: 28th March 2010, 20:33
  4. Hesitant 1.9cdti with engine light
    By DVectra55 in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 11:41
  5. 1.9cdti 150, engine light/no power @3500rpm
    By DVectra55 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd September 2008, 22:54
vectra c 1.9 eml no power
vauxhall vectra c 1.9cdti spanner light on when ignition is on but goes out when started
