Thread: veccy c 2.0 dti and 2.2dti
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    Default veccy c 2.0 dti and 2.2dti
    hello,
    can someone please start there car 2.0dti or 2.2dti open the bonnet and tell my if your vacum make a grinding noise its not loud but its definately there on mine, and i dont know if its a normal noise it dont strike me as being normal,
    just incase you dont know if you open the bonnet its on the drivers side next to the bonnet open sensor it says VAC and OUT on it,
    if you pull one of the pipes of this noise stop lack of pressure i guess
    just need to know if its a noise that they all have
    in light of my recent starting issues i am having to check every last little thing
    thanks very much
    Apr 2008
    exmouth devon
    bump
    West
    Just had a look mate mine makes a humming sound & not very loud, could only just hear it along side the noise from the engine.
    Apr 2008
    exmouth devon
    brilliant dh think mines had it proper then i think the garage who did my service has put them back the wrong way round i will let you know when i find out more
    thanks again
    Portadown, N.I.
    Quote Originally Posted by dan9895 View Post
    thanks again
    As far as I recall, the pipe entering the "VAC" should go to the vacuum pump on the right side of the engine (it should also Tee off and go across the front of the engine and up to a vacuum solonoid mounted to the rear of the airbox) and I cant remember exactly where the "OUT" should go, I think it goes to the intake manifold, but I could be wrong.
    Hope this helps,
    Tim
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Will this fit my 2.2dti
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 20:25
  3. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  4. Veccy C to replace Veccy B?
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 08:49
  5. V6 Veccy-B to Oil fired Veccy-C
    By Alpha10 in forum Introduce yourself.
    Last Post: 8th February 2006, 09:22
