Results 1 to 10 of 17
Thread: Information required re automatic gearbox
    Yorkshire
    Default Information required re automatic gearbox
    I've bought a 2.2 DTi with a faulty automatic gearbox which I intended to fix myself.
    I called into a place that only repairs automatic gearbox's to get some advice infact this guy does the repairs for the VX main dealer.
    Anyway I explain the fault and he tells me staight away that coolant has entered the gearbox and the antifreeze has damaged the friction material etc. Anyway he then tells me that the gearbox swap and then VX modification doesn't work the fault will reappear the only way to fix it is a gearbox swap and then a modification which includes a new air cooled radiator for the gearbox.
    Has anybody else heard of this mod?
    I sure the guy's information is correct but I'd like to do some of the work myself.
    Failing this I'm considering converting the car to a manual has anybody done this or have any information on the conversion?
    Thanks.
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Just out of interest...which gearbox place did you go to?
    he's correct in that the only real cure is a new or rebuilt gearbox... don't try to flush it...and i hope it was cheap, as the jobs quite a big one and the boxes aren't cheap....
    Yorkshire
    Quote Originally Posted by bigcarman79 View Post
    Don't ready want to mention it on here incase it upsets the stealers LOL
    Yorkshire
    The car was cheap but not that cheap to justify a £2200 repair. LOL
    I'm not having much luck finding a secondhand box or anyone that does an exchange box.
    I'm seriously considering the conversion to manual tho but I'd need to get my hands on donar car because the gearbox guy did say he's already started doing rebuilds on cars that have aready had a replacement gearbox with the VX mod.
    Jan 2008
    Pontefract
    Where abouts in Yorkshire are you?
    Maida Vale
    Try www.megavaux.co.uk for a 2nd hand gearbox.
    Yorkshire
    Quote Originally Posted by Thomas1 View Post
    Thanks I've dropped them an email lets hope they can help.
    Yorkshire
    The one thing that is apparent reading this forum is that Vauxhall have a major design flaw that they are getting away with sorting out and this is saving them thousands.
    Jan 2008
    Pontefract
    Quote Originally Posted by m0cea View Post
    Vauxhall did not design the gearbox, I dont know who designed/makes them but these boxes are also found in the Volvo S80 as well as other GM makes such as Saab. These early boxes are a bit weak, its not just the Vx coolant leak that causes the boxes to go kaput, design and part faults in the box themselves cause problems...this was the case with mine...However, once the box is rebuilt with all the mods and updates done they are supposed to be reliable, ( no problems with mine -touch wood!) and they do seem more confident some how!!
  1. Automatic gearbox, recommended?
    By astradriver in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 19:09
  2. Automatic Gearbox
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 1st March 2011, 16:28
  3. Signum 2.2 dti automatic gearbox
    By apacheenzo in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 21:06
  4. Automatic gearbox oil and cooler info required.
    By m0cea in forum Engine & Drivetrain
    Last Post: 21st September 2008, 00:05
  5. Automatic Gearbox Slack
    By Russell in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:56
