Results 1 to 10 of 17
Thread: another brake thread
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    Default another brake thread
    just had new discs and pads all round fitted to my vec (1.9tdci) now the brakes seem to work fine but the thing is if i leave my foot hard down on the brake pedal it goes almost to the floor and you can pull the handbrake up just about as far as it will go iv checked the brake fluid level and have not lost any do you think the dealer has done something and should i phone them back
    Glasgow
    Yip they need to PROPERLY adjust your handbrake and tell them your brake pedal is very soft.
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    hope i get it done for free cause it wasnt like that before it went in
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The handbrake is self adjusting is it not?
    Regular Member Craig1985's Avatar
    harwich essex
    mine does this. the pedal traveling down slowly is "diesel creep" apparantly? thats what i was told. but im sure mine was sharper when it was new
    Regular Member poves's Avatar
    lancashire
    Tell u somethin , that sounds like the master cylinder to me , maybe they have wound the pistons back in wrong , or mullered them , I know this can cause the seal in the master cylinder to go adrift.
    The best way to release the fluid is to undo the bleed nipple on the caliper so not disturbing anything else.
    Hope you get it sorted mate.
    If your in the aa/rac ring em , they will have a look i'm sure , and if they have done what I think , give em hell mate.
    harwich essex
    i belive the m/c on the new vectra are "double sealed" preventing this ever happening? i do belive this is diesel creep tho? never had a problem with mine. try giving them a good bleed or even a fluid change. mine felt a little better if the m/c has gone the pedal will creep when pumped with the ignition off. mine stays nice and hard.( pedal that is lol)
    it's a quirk of the servo... as long as the pedal pumps up hard with the engine off the master cylinder is fine.....
    it is quite common with vectras after the pads are changed.. it will disappear..
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Must say after doing mine on a ramped pit, I pumped everything up, rolled off the ramp and the car wouldn't stop, bit of a brown trouser moment. After parking up and then a little drive, the handbrake sorted itself and pedal went straight back to its normal operating range.
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    they are going to take it back in on thursday morning to have a look anyway
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. Hello, my first thread ;) Vectra brake problem
    By Snod_donkey in forum Introduce yourself.
    Last Post: 2nd July 2010, 21:47
  4. Rear brake rewind tool thread pitch
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 13:03
  5. Bring back the Krays (thread split from scam thread)
    By VauxVeteran in forum General Chat
    Last Post: 26th July 2006, 09:58
