Thread: Next problem eibach springs please help
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Default Next problem eibach springs please help
    Hi guys, i'm changing the springs on the vectra and are now on to the rear springs, the thing is i have removed one spring which has an approx 50mm hole in either end to take the damper ring and spring stop. However the eibach springs have a 50mm at one end and approx 65mm at the other meaning either the spring stop or damper ring will be slack, is this normal? also would there be any changes on design between prefaclift and facelift rear springs to accomadate the differance mines a 2002
    Cheers Woody
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    this is the differance between the two springs, i have a sinking feeling i have the wrong rear springs
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Also the part no: is E10-65-007-02-22 is this correct for a 2002 dti sxi?
    Feb 2007
    Glasgow
    Quote Originally Posted by woody in shetland View Post
    That seems to be the Pro Kit for 2.0T, 3.2, 1.9CDTI, 2.0 DTi, 2.2 DTi, so that looks right.
    The springs look wrong though, they should be the same as the ones that came off.
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi Shunter, thats what i think too, i checked the part numbers and they seem to right. I wondered if anyone had seen this before when doing the swap over. All the rears seem to be rated up to the same weight so i don't know if it is just the fronts that need to be set for the weight although i allready have the fronts fitted now. I would have thought the design of the springs would be the same though. I might have to phone eibach themselves on monday and see what they say.
    Cheers Woody
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    I'm not sure if this is a part number as such but the number printed on the rear springs is 1.1 75 007 01 HA if it is the part number it would surley have to match the number on the box would'nt it?
    Woody
  1. Eibach springs
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 18:46
  2. Eibach springs !!!
    By LOCKSTOCK in forum Suspension, Wheels & Brakes
    Last Post: 21st September 2008, 18:10
  3. Eibach springs
    By carlos_superstar in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2008, 20:47
  4. Eibach springs
    By topline in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2006, 10:50
  5. Eibach Springs..
    By armoured farmer in forum Styling
    Last Post: 21st March 2006, 20:06
vectra c 2.0 dti correct rear springs site:www.vectra-c.com
signum eibach springs problems
insignia eibach problem
