Thread: bonnet shake at speed
    Regular Member effone's Avatar
    Bedfordshire
    Default bonnet shake at speed
    hello all,
    hopefully this is the right place to post this...
    recently, on a private runway that i found myself on... found that at speeds over 100mph in the gsi the bonnet seem to shake, clearly the higher the speed the worse it got... today on another test circuit at around 85-90mph experienced the same, albeit a bit windier today...
    had a look over the car, the bonnet is properly shut, i.e not on the latch which is how it first seemed...
    has anybody here had the same thing happen to them... would be nice if there was a fix as it's pretty scary when this happens...!!!
    thanks all
    ian b
    Are the bonnet stops adjusted correctly?
    Bedfordshire
    mmm not sure to be honest... feels pretty firm when it's closed... how do i check...??
    are there rubbers on the slam panel that you can wind up...???
    cheers,
    ian
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    funny you should say that mate, mine also does this when going quite fast, and all tight and fastened down correctly.......
    Midlands Mod Shop - NFFC.
    Quote Originally Posted by effone View Post
    cheers,
    ian
    yes I think there is, i have never really looked
    Pretty sure mines solid at speed, I'll check next time
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There are four such adjustable stops. Try grasping the bonnet and trying to lift it, and also try pressing it down where the stops are to see if there is any play in them. There should not be any gaps betweent the rubber stops and the bonnet itself. The area where they contact will shows signs of gaps and or movements if you look closely.
    Look here, cicled in green for the stops.
    Bedfordshire
    cheers for the info fella,
    i'll have a look tomorrow and let you know how i get on...!!
    cheers,
    ian
  1. wheel shake
    By franko in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 13:35
  2. help help? steering shake/wobble
    By dazy75 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2011, 00:46
  3. My bonnet flaps around at speed. Anyone else's doing the same?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2007, 22:02
  4. Shake And Shuddering At High Speed
    By JACKALG1 in forum Suspension, Wheels & Brakes
    Last Post: 21st November 2006, 20:39
  5. shake that A##
    By murf2484 in forum Comedy & Humour
    Last Post: 20th May 2006, 12:57
