Thread: Secret Menu on Display ( Test Mode)
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Default Secret Menu on Display ( Test Mode)
    There has been a few threads before on this issue and the info that you can obtain via the secret menu. Not all Vec-C's seem to have this menu but would I for one would like to get to the bottom of all of the info in it.
    My Vec is a 2005 Pre-facelift 1.8 with CD30 and a Basic display.
    Firstly, to get into the Test Mode I do the following.
    1: Switch ignition on until lights display on dash.
    2: with radio switched on (My CD30 switches on automatically anyway) Press and hold settings until an audible bleep is heard. The radio is now in Test Mode.
    3: if you repeatedly press the right hand button under the display, you will cycle through 16 options. This is the button that looks like a bullseye, whereas the one on the left looks like a clock. These are as follows:
    1)HW;D1.30
    2)01.12.2004
    3)SW:4176a/0
    4)24.06.2004
    5)DD:4.B/6.0
    6)CODE:001/01
    7)LS:FF010000
    8)MS:4200
    9)DIMM:None
    10)0.0100 100
    11)LCD:36 OC (AS IN DEG C)
    12) U30:12.2V
    13)RDS-T:12:16
    14) PI-EHU: OC
    15) SENS.: 18.0
    16)V: 0 T: 36
    To exit test Mode, simply press and hold SETTINGS button until bleep is heard.
    Now, I can shed some light on some of these options above.
    2,3 and 4) I'm guessing, when the ECU or electronics was manufactured, Software version and installation date of the latest software. As my car was registered 23.02.2005 and certain body parts are date stamped Nov 2004, I'm guessing I might be right on this???
    9) When engine running, will flash between None and U (Just the letter U) when Hazard Warning lights switched on.
    10) The second 100 fluctuates when the engine is running but always stays above 93. When you switch the lights on, all values drop and dimming the interior dash lights takes down the values further.
    11) This value does change, but I don't know what it relates to???
    12) is charging voltage /battery voltage. As car was switched off when I typed these, on the move, it registers typically 13.7 volts upwards.
    13) is the time the RDS clock updates or was last updated.
    15) Seems to be just between 0.5 and 1 degree out from the temperature in the display. I suspect this reading is real time and the one on the cars display takes an average over a pre-determined time.
    16) is speed in KM/H then engine temperature. This corresponds exactly to the gauge on the dash when engine is warm. When warming up, the temp on the secret menu seems to warm up quicker!
    I'm of the opinion that none of these settings can be modified, so I don't think we'll be ruining our cars and I think the guys on here with colour screens etc will get a lot more info.
    Can anyone shed any light on the others????
    Regular Member Eskimo's Avatar
    Feb 2011
    Scotland
    Sorry to bring back an old thread, however being new to the 'Secret Menu' I have no idea what a lot of the settings mean.
    I have tried using the search facility and although I've found a lot of references to it there's nothing that explains what all the reading are.
    Have I missed something?
    Regular Member LADmachining's Avatar
    Hampshire
    Have a look at these thread which may help to shed some light on things.
    Although the threads show screens from the Astra, the Vectra full CANbus models should be the same.
    BID 3 line display
    http://www.astraownersnetwork.co.uk/...d.php?t=110104
    CID - Colour Info Display
    http://www.astraownersnetwork.co.uk/...d.php?t=110731
    May 2007
    Thanks for reviving the old thread.
    Most of the info in the TID display like mine is the same as you can see.
    Feb 2011
    Scotland
    Fantastic, thanks for that.
    Dec 2010
    York
    Can you change any details while in the secret menu? I am wanting to try and enable the display to show MPG and other details
    Dunstable
    Quote Originally Posted by ian124 View Post
    No, you can't enable/disable anything in the hidden menu
    May 2007
    This involves a change of display and plugging in the car to Tech-2 to enable the new screen/functions.
  1. Secret menu, can i get trip computer programed to my car?
    By Niall83 in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2011, 19:17
  2. Accessing secret menu on prefacelift Signum
    By Celes in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2011, 15:15
  3. Secret test mode screen shots Vectra C
    By astrocat in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2009, 23:41
  4. secret menu or not ??
    By Devil Nev in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2008, 17:46
  5. Rubbish MPG And The Secret Menu
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2006, 20:27
astra h hidden menu
how to select things in test mode on vauxhall vectra breeze c cd30
what does the vectra c secert menu all mean
astra h secret menu cd30
vectra c test mode
test mode opel vectra
corsa c test mode
astra hidden menu meanings
vectra test mode
zafira test mode cannot exit
secret settings menu vauxhall zafira
Astra H cd30 secret menu
opel zafira testmode menu
corsa c hidden menu
vectra c hidden menu meanings
astra h secret menu explained
opel asta h bc test mode
astra h hiden menu v.
test mode opel vectra c
opel cd30 showing program display
opel astra h test mode out
astra testmode: cc
zafira tid hidden functin
astra 2005 secret menu press select
display mode vectra c
