Thread: Urgent eibach springs
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Default Urgent eibach springs
    Hi guys, i'm putting in my new springs at the moment and there is a plastic sheath covering the 1st lower coil on the front two springs, are these meant to stay on or are they there to indicate top or bottom etc then be removed whilst fitting.
    Woody
    Regular Member david.aka.judas's Avatar
    Suffolk
    i think they are meant to stay on - they are there to stop the squeeking you get from metal to metal contact.
    if i remember correctly, thats the suspension mod that vx do - just put plastic covers on the bottom of the spring.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    yep ment to stay on m8 they sit in the cup to stop noise..
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi Judas, i tried the spring on the strut and it only fits with the plastic coil around the top where the rubber gaitor protects the shock. would this sound correct ?
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi steve, So the plastic sleeve definatly goes at the bottom of the spring?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    From what i remember the springs only fit one way,if the plastic is on the top coils that's where Eibach want it,you could still fit the plastic from your old springs though.
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    okay, i'll fit them with the plastic to the top as it seems the only way they will fit as one end is a different size to the other. Thanks for your help guys.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The plastic sheafs were put on to stop spring noise, usually fitted under warranty when the customer complians about noise from the springs. Dont bother fitting them back on as I have never had any noise with my Eibach springs on. They are much better quality than vX
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Fitted them to my Eibach's with no issues.
    Edit:- Plastic cover was on the bottom coil.
  1. Eibach springs
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 18:46
  2. Eibach Springs
    By lizard in forum Handling & Braking
    Last Post: 4th August 2008, 14:53
  3. Eibach springs now on !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2008, 08:47
  4. Eibach springs
    By topline in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2006, 10:50
  5. Eibach Springs..
    By armoured farmer in forum Styling
    Last Post: 21st March 2006, 20:06
