Thread: Spanner light coming on P0115 fault code help please...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Spanner light coming on P0115 fault code help please...
    Thought things were going to well with my car since the BSR remap.
    The spanner light has been coming on and at the same time the temp gauge drops to zero. It happens when the car is sitting idleing. When you pull away the spanner light goes out and temp gauge comes back up again. Today a friend put the Tech 2 on and it came up with the code P0115 Engine Coolant Temperture Circuit High input. We think it is the Coolant temperature gauge that is breaking up. Anybody got any ideas or had this problem before?
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    P0115 Engine Coolant Temperature Circuit Malfunction <---- thats what i got
    replaced temperture sender unit no problems then well with that anyway!
    HTH
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Update...issue caused by VX!!!!
    Went to check that the plug was fitted correctly to the sensor to find that the yellow safety clip had not been engaged at all and the plug was not fully fitted. The last person to touch this plug was VX when they swapped the engine over under warranty. Decided to have a quick look round and found three other plugs not correctly seated with safety clip not being used.
    Typical issue caused by VX tech............ not pleased and will phone Vx and tell them what I think!
    Hopefully this has solved my problem but only time will tell. Need to clear the spanner light now, any one know how?
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    I think it'll clear after 25 restarts, providing another fault or same fault doesn't re-occur. Or if you vent your spleen at VX over the loose plugs, they may just clear them for free. No harm in asking....
  1. Replies: 11
    Last Post: 2nd December 2011, 08:47
  2. water in diesel filter, spanner light and fault code
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2011, 19:24
  3. Spanner light; error code 'Preheat delay fault'
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 24th April 2009, 16:33
  4. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
  5. Spanner over a car light keeps coming on
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2008, 20:29
vauxhall vectra p0115
p0115 opel vectra
