Thread: Tick over / idlespeed ? 3.2
    Regular Member poves's Avatar
    lancashire
    Default Tick over / idlespeed ? 3.2
    I have just had the top half in pieces to change the oil cooler , and after the rebuild everything is ok apart from the idle speed , it seems to hover around 1000rpm sometimes wobbles a little higher then randomly drops down to 750rpm ?
    I did have an issue with the idle valve gasket but it is sealed 100% (sealing compound)
    Everything is back on and in the right place ( I hope)
    Could it be something is clogged with all the milkshake type stuff I had to flush out of the cooling system ?
    Help me guys it is doin my box in !!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    sorry mate can't help you, this is one for mark or drinky me thinks...
    Midlands Mod Shop - NFFC.
    Mileage : 000
    Could the idle control valve need cleaning, posibly some "gunge" may have got in there and is clogging it up a bit. I had to clean the ICV out on my wifes Vectra B quite offten, untill the valve needed replacing.
    lancashire
    Quote Originally Posted by ed taylor View Post
    Doubt it mate, I cleaned everything meticulously with carb cleaner , so as it stands I'm stumped , maybe if the weather is a bit better tomorrow I will have a look again , maybe take the plenum off again and double check everything - I still have a feeling that something is blocked somewhere , maybe a breather or a warm air pipe to the intake system , after all there has been loads of oil and water mixed together pumped around the cooling system , which resulted in a very unpleasant brown/orange gloop.
    So if anyone has any ideas let me know pls
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Is the TB all clean mate, such a simple thing to over look. Also are all your vac hoses all air tight and plumbed in?
    lancashire
    As far as I can see everything is ok ,
    Will have another look tomorrow
  1. tick tick tick tick ? ? ? ? ? WTF!!!!!!
    By ciderman in forum Vectra C / Signum Troubleshooting
    Last Post: 30th August 2012, 19:37
  2. Still got the Tick
    By Collis in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 19:47
  3. Tick tick tick, DAM IT
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2011, 15:31
  4. Tick tick tick Crunch
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 18th April 2011, 14:25
  5. Tick Tick Tick BOOOOM
    By staticbob in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2007, 15:42
