Thread: Bonnet release failed
    Regular Member cabbage's Avatar
    Bristol
    confused Bonnet release failed
    Can't release the bonnet using the drivers side pull handle, the bonnet is tightly shut. Any other way of opening it? Need to check the oil but last time I checked it was near full. 200mile journey to Cumbria on holiday for a week tomorrow. Help!
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    just get someone to push down on the bonnet for you will you pull the release ..........this should work.............yours is probibly like mine and needs greasing
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    well you can try pulling bonnet release at same time someone pulling bonnet up, it may work but cable may have had it,
    you car try dissconnecting cable from bonnet relase handle and pulling it with pliers ----- might work???
    in which case i think the only when it is to remove the headlight,
    this is a really awkward task.
    headlights arent designed to be removed with bonnet closed specialist tools required,
    or by replacment headlight of ebay.
    and a hammer --------still be cheaper than stealers
    HTH
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    This thread might help mate, pic as well
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    i had this problem, if i pulled the handle, and someone else pulled the bonnet up it was ok.
    Next to where the bonnet clicks in, there are two black rubbery things, unscrew them slightly, and it solved the problem
    Regular Member jamesr's Avatar
    Lancashire
    If the above doesn't help, you can remove the grille from underheath easily with bonnet closed.
    Then simply push the catch.
    Seems to be a common fault, the cable slips out of the bracket securing it to the front of car.
  1. bonnet release
    By Pete Elite in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2015, 00:27
  2. 2.8V6 bonnet release ....do it now !!
    By Deztroyer in forum Bodywork & Interior
    Last Post: 14th June 2011, 22:45
  3. Bonnet release
    By Admishere in forum Bodywork & Interior
    Last Post: 23rd March 2011, 15:26
  4. bonnet release
    By ade0303 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 20:39
  5. bonnet release
    By magpie27 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2009, 14:08
