Results 1 to 3 of 3
Thread: More EGR problems
    Essex
    Default More EGR problems
    Hi all Can anyone give me any advice my 53 reg Vectra 2L Dti keeps on getting the service light flick on and sometimes goes into limp mode, I've had it on a diagnostic and came up with po400 EGR and po638 accelerator sensor so I changed the EGR valve for a new one and checked all the thin black pipes and connectors for splits and also swapped the two white pipes over that go on the two solenoids at the front right hand side of rad, I,ve also cleaned out the metal throttle body on top of the EGR valve and made sure the flap is working OK, I'm now baffled. Anyone got any pointers would appreciate it.
    Thanks John.
    Aug 2009
    North East
    Hi, did you get to the bottom of this. I have both these codes on my Signum 2.0 diesel and mechanics are scratching their heads as to what the problem is. Any help would be appreciated.
    Thanks in advance
    R.
    Regular Member eaglepva's Avatar
    Up North
    was their any other symptoms with the EGR valve?
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
