Results 1 to 10 of 13
Thread: Steering vibrations
    Regular Member Wilco's Avatar
    Aug 2007
    Default Steering vibrations
    Hi guys advice time please, i'm suffering badly with vibrations through my steering wheel but only between 70- 75 mph. Had the wheels re-balanced and its actually made it worse. Its not a constant thing either comes and goes but is quite bad at times. any suggestion? this is on a 56 vec estate btw with 19's. Looked into buying new tyres as the avon ones that are on it are cr@p to say the least. cheers in advance guys.
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    I’ve had this a few times and it ranged from the tyres not being balanced properly (leaving weights on or duff machines) to a faulty tyre which was replaced (around 70mph is the normal for any balancing issues I have had).
    You could try a bit of detective work to track down the problem – swap fronts and backs and see if the problem disappears.
    Best of luck sorting it
    Regular Member DARREN R's Avatar
    Jan 2008
    WASHINGTON
    Vehicle : vectra
    Trim : sri xp
    Engine : z19dth
    Mileage : 93000
    ive got exactly the same problem m8
    Aug 2007
    Cheers swatty, problem i have is the rears have less than 3mm left on em so need replacing anyway. Going getting 4 new tyres this afternoon and keeping my fingers crossed thats what the problem is/was.
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Quote Originally Posted by Swatty View Post
    I had this problem and it was due to the idiot that balanced the wheels left the old weights on and added more to balance the wheel. This resulted in the wheel being over weighted and a shuddering at around 70mph. the old weights should always be removed before balancing a wheel
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    I had problems, had them balanced plenty of times (twice with fine weights) and still had the problem.
    It was cured by replacing the tyres in the end.
    Aug 2007
    Quote Originally Posted by JuzzyD View Post
    THats what i'm hoping for . Cheers guys!
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by Wilco View Post
    Mine is exactly the same on 18" snowflakes. I fitted the TPMS valves and had the sport contact 2's re-fitted and balanced. Slight wobble through 70-75. I have swapped the wheels about but it's still there but only now and again.
    Sunny Dartmoor
    So many factors can affect the geometry of your motor,its just a case of illiminatation,good luck Wilco.....
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by leeds vectra View Post
    thats whats happening to me it only wobbles every now and again!! i found out that one of my alloys is buckled and thats whats causing it.
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. Strange vibrations
    By BigWilko in forum Engine & Drivetrain
    Last Post: 13th March 2012, 20:28
  3. Bad vibrations
    By tony tyre 1 in forum Troubleshooting
    Last Post: 25th November 2011, 07:25
  4. Vibrations?
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 15:40
  5. Vibrations!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 11:39
