Results 1 to 10 of 15
Thread: Cruise Control up the spout :(
    Apr 2008
    Northumberland
    Angry Cruise Control up the spout :(
    Hi all, my cruise control suddenly stopped working, it was ok on the way to the shops but nothing on way back (typical the week before my holidays ), I've had none of the speed up symptoms others seem to have had it simply refuses to turn on. I've read a few posts on here and tried the 'lifting the brake/clutch pedal' trick but no luck.
    I've also read that removing the stalk and spraying/cleaning the connectors may help - is the stalk easy to remove? I'm pretty technical minded but don't want to go at it with a hammer if you know what I mean
    Can it only be the stalk or the pedal switches or is there a relay etc? I've seen a couple of replacement stalks on eBay for about £30, anyone know how much Vx charge for one?
    Oh yeah and it's just out of warranty - ain't that a shocker
    Thanks all
    Dave
    Regular Member SignumPhil's Avatar
    Luton, Beds
    My switch on the stalk does play up sometimes -a good hard prod seems to sort it out.
    Phil
    Maida Vale
    Fitted a new stalk just this week to my wife's Signum - you just pull the stalk out, carefully but does need some effort. I also saw a £30 second-hand stalk on eBay, but bought it from a main dealer for £33 inc VAT (although it's not a Trade Club item they reckoned).
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    You have pressed the brake pedal haven't you - it will only work once the brakes have been used.
    May 2008
    St.Albans
    I'm too scared to even try mine, must do one day
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Mine some time splays up, a quick few firm presses of the rocker switch up and down usually sorts it. Probably dirty contacts that i'll get round to cleaning one day.
    If the CC won't engage with either up or down of the rocker switch, and the clutch and brake switches are working OK, then it may be a bit more serious.
    May 2008
    St.Albans
    Smile
    Tried mine today on the A1(M) on the way back from Stevenage, all good
    Full Member stuart bigboy's Avatar
    May 2007
    kent
    Default cruise controll
    had the same on mine dealer changed the stalk works fine now
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    heard something about the clutch return spring affecting cruise control try and put your foot under the clutch pedal and gently pull towards you
    Apr 2008
    Northumberland
    Quick update, I removed the stalk to find the white lubricating grease/compound had contaminated the metal connectors.
    I cleaned them off and the CC is working again now.
    Thanks all
    Dave
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
