Results 1 to 10 of 15
Thread: Power from battery to boot help?????
    South Wales
    Default Power from battery to boot help?????
    Hi all is there a way of getting power from the battery into the boot without drilling the bulkhead? I have power cable to run from the battery to the boot and wondered if there is an existing grommet or hole i could use? I am installing 2x 3000watt subs with 2x 2500watt amps so i need a meaty supply!!!
    Regular Member poves's Avatar
    lancashire
    Jesus with that sort of install y not just put a generator in the boot ?
    My mate did this job (cable routing) a while back , i'll find out how he did it m8.
    South Wales
    that would be fantastic, i dont really want to be drilling my car, yeah it is quite a bit of power, im no boy racer being 31 but i am just mad about music!!
    Jan 2006
    Skynet HQ EMEC#5
    Right, I've just taken a couple of pictures to show how my cable is routed:
    There is a grommet in the corner under scuttle panel on the passenger side.
    To get to this from the inside, take out glovebox.
    I then tucked the power cable under the edge of the plastic inside sill trim all the way to the boot.
    HTH
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So that's 5000 watts total (peak or RMS ??) so that is 417 amps !!!!!!!! at 12V.
    That is one mighty power consumption if you're drawing full power.
    I hope you have a good alternator, battery and a very good cable to the rear. At that power handling, you are looking a heavy duty starter cabling to minimise losses and heat.
    Might be a good idea to fit an additional battery in the boot to handle the power peaks
    South Wales
    ah thats fantastic i will print the photo and route it the same way, thanks a lot for that saves me drilling my car which obviously encourages rust and leaks. I will be installing it sunday and then fitting the subs and amps when they are delivered next wekk so i will post some piccies....thanks again
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Not calling you a fool but make sure that the grommet is seated in again correctly as i didnt and ended up causing more problems than i care to mention lol
    South Wales
    it is 5000watts peak music power, not sure on the rms, i have bought 0gauge cable, its the biggest they had in the shop, i thinks it 0gauge neway, its really thick, bought similar size earth cable. I will see how the battery and alternator deal with it, i will buy a new heavy duty battery if it struggles, and possibly upgrade the alternator if i really have to???
    South Wales
    i will put in a bit of expanding foam inthe grommet to make sure it is sealed
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Remembering the alternator is about 100 amps (maybe 120amps) max charging, you may end up running out of electrical power.
  1. Connect USB cable to car battery without power socket.
    By Echelon in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2012, 17:32
  2. Flat battery, now no power steering
    By Tony12 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 19:09
  3. Signum from battery to boot
    By nalaremlap in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 22:48
  4. Power Steering or Battery/Alternator problem ???
    By kizalini in forum Engine & Drivetrain
    Last Post: 23rd November 2009, 00:50
  5. Flat battery and cicking sounds from fuseboxin boot
    By Stevo K in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 15:18
vectra c cable from the baterry to boot
vectra c boot power supply
