Thread: New intelligent lighting fault handling
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default New intelligent lighting fault handling
    We all know about the rear side light braking system lighting and the fact that the bottom light is illuminated if the top bulb has blown.
    BUT, did anyone know that if a front side light is out, that side front indicator is illuminated at half voltage continuously? If the indicators are then turned on, the light blinks on / off at full voltage, then reverts back to steady half voltage upon cancellation. Found it out last night when the bulb failure icon appeared
    Clever.
    Chester
    Never knew that.
    I guess from a purely electrical point of view it's fairly easy to do. The real shock is that someone at VX had the imagination to come up with the idea in the first place.
    Sunny Dartmoor
    What a great system,those guys at Vx need to get out more......
    Regular Member SignumPhil's Avatar
    Luton, Beds
    That's clever. I suupose the canbus gives control of any light from anywhere. Wonder if you could really mess someone's car up so the windows opened when the headlights were turned on? Or the hazard flashers switched on when you adjusted the mirrors? Should only be a case of fiddling canbus controller addresses...........
    Phil
    Lutterworth, Leicestershire
    [quote=SignumPhil;656933 Wonder if you could really mess someone's car up so the windows opened when the headlights were turned on? Or the hazard flashers switched on when you adjusted the mirrors? Should only be a case of fiddling canbus controller addresses...........
    Phil[/quote]
    LOL!!!
    What a GENIUS idea!!!
    Jun 2007
    Black Country
    Phil[/quote]
    already been done mate
    its called a Renault
    Chester
    Quote Originally Posted by Guyver1 View Post
  1. Adaptive forward lighting fault
    By Sigmacca in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2016, 21:06
  2. Handling?!?
    By krzyzu in forum Handling & Braking
    Last Post: 17th February 2009, 22:10
  3. Handling help
    By crucial in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2007, 01:05
  4. handling
    By brant2474 in forum Handling & Braking
    Last Post: 12th December 2007, 23:40
  5. Handling?
    By danny2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th December 2005, 22:39
vectra c lighting fault
