Results 1 to 10 of 17
Thread: Blown bulb warning light on dash??
    Regular Member Genterz's Avatar
    Herts
    Default Blown bulb warning light on dash??
    I've only had my Vectra ('53) about 2 months now but it's always shown a "bulb symbol with exclamation mark in it" and a "brake disc warning light" for the first 30 secs on start up. All bulbs are fine and the brakes were replaced by the previous owner. He said they must have forgot to reset the warning lights.
    Is there a secret combination of buttons to press to reset them myself?
    I've found on the web how to reset the service light reminder but nothing for the above.
    Can anyone help?
    Cheers.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    bulb warning light might be a bulb on it's way out....and perhaps the pad low indicator was not replaced when pad's were done
    Midlands Mod Shop - NFFC.
    The brakes one, did they replace the sensor wire? It should be done when the pads are changed as they are a one use type affair.
    Here, there and every where!
    You could try changing the brake sensor cables. They are fragile and could have been damaged when the brakes were changed.
    Trim : Get a
    too slow gent's...... lol
    Also if its a break light, the veccy will use the fog light in its place, It has caught many a person out. Check the exact same lamp is lit on both sides
    Bah silly gurus!!!!
    Herts
    Interesting about the fog light, never heard that before.
    So is it easy to replace the sensor wires yourself? I'm hoping the sensors themselves won't need changing too?
    Trim : Get a
    if you are mechanicaly minded then yes, if not, not too hard a job realy, but get a mech to do it for you if you are unsure, i am sure there is a how 2 somewhere on here...
    I think the bit about the fog light or sidelight which i think it is, will be in the manual. I'm pretty sure I was wrong with it being the fog light as the veccy only has one, so it must be the sidelight. Basically, check all the lamps are secure and their connections are clean
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Genterz View Post
    The wire and the sensor are one part mate.
  1. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  2. 05 Vectra CDTi - Blown bulb warning light?
    By gmc in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2010, 21:29
  3. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  4. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
vauxhall vectra bulb warning light reset
how to reset dash warning lights on my vectra
vectra c dashboard bulb reset
vectra c bulb warning light reset
how to clear dash warning lights vectra
how do you reset the warning lights on a vauxhall vectravauxhall vectra warning lights on dashboardreset service light on vauxhall vectra 2003vectra engine warning light resetlight bulb warning light on vectravectra c bulb warning lighthow to reset light bulb warning on combovauxhall vectra reset light bulbsvauxhall vectra reset bulbsvectra c bulb light failure resetvectra c how to clear the bulb warning how to clear bulb light vectravauxhall vectra light bulb warning light resethow to reset bulb warning light vectravectra c warnilg lightsHow to reset faulty bulb icon on dash vectravectra c fog light bulb warning on dashboardvectra c dash bulbs layoutvectra dash says bulb out but its still lit
