Results 1 to 3 of 3
Thread: What are these ??????????? pics included
    london
    Default What are these ??????????? pics included
    I want to change my stereo, i know the two bottom plugs are to do with the stereo, but what is the big top one, also will i retain the dash display which shows track number (shown in last pic) and the steering wheel controls, my car is also fitted with bluetooth will this also work, with the new system, is as simple as plug n play.
    1. what adpaters do i need?
    2. what colour facia?
    Also how do i remove the cage is it straight forward.
    I would appreciate youre help.
    Thanks.
    Here, there and every where!
    Steering wheel controls
    Cage pulls out after bending the lugs back in, you have ISO plugs so any stereo should fit. You will lose the ability to change the clock but trip computer will still work if you fit a steering wheel loom depending on what headunit you fit
    Bluetooth, not sure, it will probably be linked through the standard unit
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you will not loose the ability to change the clock.. as that can be done via the BC stalk. only thing without steering wheel loom you cant control an aftermarket unit all other things shoul not be changed (i can se u dont have a cd30 but a CRD2005)
  1. Replies: 18
    Last Post: 23rd August 2012, 21:49
  2. Hello from Scotland (pics included)
    By skene in forum Introduce yourself.
    Last Post: 17th July 2012, 01:08
  3. Is this right? (fuel pipe seems to move) - Pics included
    By Dane-10 in forum Engine & Drivetrain
    Last Post: 16th May 2012, 21:48
  4. What is this pipe ? (pics included)
    By Shrimpy in forum Engine & Drivetrain
    Last Post: 31st March 2010, 17:12
  5. HELP, cleaning the EGR valve pics included.
    By eaglepva in forum Engine & Drivetrain
    Last Post: 13th February 2010, 21:42
