Results 1 to 3 of 3
Thread: Vectra boot not locking
    Nottingham
    confused Vectra boot not locking
    Hi i have an 04 reg vectra, the boot no longer wants to lock into the catch, so is constantly open? The button also doesnt make its electric type noise anymore?
    Any ideas, its just i dont know if its an electrical fault or something simple like a fuse??
    Any ideas would br gratefully appreciated Thanks Amy
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Sounds like the boot lock catch/ solenoid is stuck or broken keeping the catch in the open position?
    Gillingham
    Yep, I have just had the same fault, had to tie down the lid to get back home. I have taken the electronic bit off the lock itself, this allows the catch to operate mechanically and close the boot. You need to make sure you leave the trim unclipped, because you have to unlock the boot manually by tripping the lever on the inside of the catch which means accessing via the inside of the boot, bit of a pain, but at least you can get the boot closed until it is repaired. I can't get the switch to peices to see if something is broken, thought it was just stuck, but that hasn't worked, going to have to check outsome prices.
  1. Disable auto locking boot feature
    By RAMBIRKETT in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2010, 01:43
  2. Central locking opens boot
    By littlecretta in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 18:30
  3. Locking - second button push/boot opening.
    By DaveV in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2007, 20:32
  4. drivers side cenral locking switch and boot opener not working
    By mattdiesel in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2006, 22:40
why does 2006 vectra tailgate keep lcking itself
