Thread: Heater problem with air direction, poss canbus?
    LIVERPOOL
    Default Heater problem with air direction, poss canbus?
    Had a new stereo installed in 3.2 gsi 04 all works graet but i dont seem to have any heated front screen and the air direction control does not do a thing.
    It all worked fine befor though.
    Any ideas
    Have you checked all the wires are still plugged in? You may have accidently pulled one out while fitting the stereo.
    LIVERPOOL
    Yes all in mate
    Wales
    Fuses are the next thing to check then...
    Feb 2006
    Dorset
    pull the battery for an hour , might reset its self .
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    not sure what you mean with new stereo but if you have ECC and if the display has been replaced the ECC needs to be paired again via Tech2...
    Don't think he has replaced the screen, just removed the stereo. Would this need doing on a half canbus car?
    Wild AL, do you have buttons on the steering wheel? or the scroll ones?
    LIVERPOOL
    Its a alpine multi media unit so just the stereo out. I have buttons on the wheel i believe this is cambus operated.
    The standard stereo i took out was a ccr2006 i think built in 4 disk changer
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I think all radios with a graphic or color display (CCRT..., NCDC...) are paired via Tech2 and anyhow the ECC is linked to the unit: after a radio has been replaced, in the reprogramming the ECC must be checked (but I don't know if all GSI's have ECC)
    I think someone should call Dr Tech2
    LIVERPOOL
    What is a eec?
  1. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  2. Heater direction settings
    By vectra_06 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2012, 22:47
  3. Poss Boost Control Valve Problem
    By RS2000CUSTOM in forum Engine & Drivetrain
    Last Post: 10th June 2011, 12:33
  4. heater direction control knob problem
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 22:40
  5. Peculiar light / canbus problem
    By 19CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2010, 21:50
