Thread: Feeding wires from engine bay to interior - driver side
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Default Feeding wires from engine bay to interior - driver side
    Hi guys,
    Is there anywhere for wires to be fed into the car on the driver side. I need to feed some wiring through for my gauges.
    Thanks.
    Sunny Dartmoor
    Think if you remove the clocks you'll see a grommet or too........
    http://forum.vectra-c.com/showthread...5837#post65837 - explains it in words. if you need pics let me know.
    Basically you remove the wipers and the wind/water deflector. On the drivers side, you'll just be able to see a grommet to the far side of where all the linkage etc. is. Pop the grommet out, push a hole through it and you can feed the wiring through it. On the cabin side you'll need to remove the trim under the steering wheel and then you'll be able to pull the cable through to tap off your power feeds. If you want to make it easier to feed cables up to the dash by the side of the A pillar trim, remove the pillar trim and also the cover on the side of the dash - the bit you see when you open the door - and you'll see that you then have gaps to help you feed cables up.
    May 2007
    Nice one guys, cheers. Does the A-pillar trim come off easily?
    Sunny Dartmoor
    Yeah just pop out the inserts and pull,very easy......
    Yep, just gently prise up the little plastic tab that says 'Airbag' on it (don't worry, there's no airbag behind it - that simply identifies that the car has a side-curtain airbag) and then pull it out as far as it will without pulling it off. That unlocks the clip that holds it in place, then just pull the trim off. There will still be a one or two retaining clips so it needs a bit of a tug, but there aren't any more locking clips.
    May 2007
    Brilliant, cheers!
  1. Which wires on interior light?
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2013, 12:23
  2. HELP, feeding wires through dash (footwell lights).
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2009, 09:12
  3. wires into dash from engine ?
    By Silver Vectra C in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2007, 11:25
how to get from engine bay to driver bay cables corsa c
how can i get a wire from the engine bay to the footwell in a vectra c
How to get footwell trim off vectra c
