Thread: How do you remove the plastic inserts by the Fogs ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default How do you remove the plastic inserts by the Fogs ??
    As above
    I have done a search but to no avail & i did not want to be to brutal
    But how the devil do the plastic grill's come out of the bumper, The ones that are by the Front fog lights..
    Don't tell me i have to remove all the belly Tray !!
    Dean
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If your's is a facelift they're held on by clips and a few plastic welds,out with the dremel i'm afraid.
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Is yours a facelift or a pre-facelift Dean?
    If it's a facelift then officially you need to remove the bumper. (Easy job).
    But the shortcut way is to just give them a good sharp yank as the only thing holding them in are a few plastic tabs that are melted over. Melted plastic becomes brittle so they will break easily enough.
    If it's bumper off then open the bonnet, remove 4 Torx screws from above the grill, 2 in each wheel arch, and 4 plastic clips underneath and it's off.
    Hope this helps.
    Snowman, you got your ears on?
    Nov 2007
    Staffordshire
    Cheers All.
    Pre Facelift 54 Plate ..
    Dean
    Here, there and every where!
    Bumper off is easiest. Half hour job
    Sunny Dartmoor
    How did you get on Dean???
    Nov 2007
    Staffordshire
    Quote Originally Posted by glenboy View Post
    Glen.
    Not got around to it Yet Work always interfere's with your playtime
    Dean
    Sunny Dartmoor
    Know what you mean.....
  1. how to remove plastic piece from seats
    By antowens in forum General Chat
    Last Post: 10th December 2012, 00:34
  2. How do I remove the plastic door pillars?
    By Innes in forum Styling
    Last Post: 7th September 2011, 14:49
  3. How to remove plastic plate underneath engine?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 21:19
