Results 1 to 3 of 3
Thread: changing rear suspension arm
    Regular Member dan1983's Avatar
    North London
    Default changing rear suspension arm
    Hi guys just ordered new supension arm from lmf (didnt realise its cheaper on ebay) will be fitting it this weekend, is it worth changing the arb at the same time, also ive only ordered one on the side of the knocking should i of done both. last question do i need to remove the springs to change the arm. thanks
    East Midlands
    Quote Originally Posted by dan1983 View Post
    If it's the rear upper control arm when i did mine i just removed spring for easier access to rear bolt...it's advisable to replace in pairs m8 cus you are in effect altering your rear suspension set up...for the price of the arb well worth doin em while you've got the wheel off .
    North London
    cheers
  1. Changing Suspension
    By hothatch in forum Handling & Braking
    Last Post: 26th April 2012, 20:38
  2. Changing rear spring
    By tyler boy in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2011, 11:37
  3. Changing Rear Discs
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2008, 21:35
  4. Cost of changing rear springs
    By gekornro in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 20:04
  5. Changing rear shocks
    Last Post: 16th December 2006, 22:54
