Results 1 to 10 of 23
Thread: cant get my inlet manifold off!!!
    Sussex
    Default cant get my inlet manifold off!!!
    hi guys, i've got a 2.2 direct petrol vectra and the inlet manifold has gone up the swanny, so i thought i'd take it off..
    took off the egr pipe, loads of electrical bits and bobs, the throttle body etc and the manifold was full of gross black sludge and oily slop.
    so i carried on removing stuff but can take the manifold off!
    the dipstick is in the way for a start!
    what do i do?
    CURLY
    Sussex
    sorted!!
    i have booked it into Vauxhall tomorrow so they can do whatever they need to do!
    ahh, big releif!
    CURLY
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Good luck and let us know how you get on Curly, I have the Direct engine in mine and might think about getting all that cleaned up as a preventative measure.
    Sussex
    if i were you, i would take the throttle body off, which i easy peasy, pull out the direction pipe inside the inlet manifold and clean that and inside the manifold as best you can, cos mine was well gunked up!
    also, ask Vauxhall to sell you an egr blanking plate, and have the ecu re-programmed not to use the egr valve, it will stop the black soot and crap going into the manifold.. you'll know what i mean when you take that direction pipe out!!
    just be careful not to drop anything into the manifold, cos it looks well deep!
    CURLY
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Not all 2.2's can have the egr tech 2'd out!
    Sussex
    oh.. can mine? its a 2005 one
    May 2007
    I think it is only possible on the earlier models, non-direct, but I could be wrong.
    Sussex
    oh, well the guy has said that he'll do it, so i'll let you know if it can or not!
    CURLY
    Apr 2006
    Mines an 05 Direct too, cheers for keeping us informed Curly.
    Sussex
    ahhh! my car is all sorted now!!
    the EGR valve can be tech 2'd out, i had a blanking plate put on mine, and the new manifold doesn't have the egr valve hole in it either, so the egr valve and pipe went straight in the bin!
    it is so much better without it! and now i dont need to worry about all that black sooty oily crap going into the engine!
    i'd recommend having the egr valve removed and blanked off to anyone..
    they are the spawn of satans sweaty jock strap if you ask me!
    CURLY
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
