Results 1 to 4 of 4
Thread: How do you remove/replace the vxr insert????
    Regular Member Baz07's Avatar
    Mar 2008
    Lancashire
    confused How do you remove/replace the vxr insert????
    Can any body that has the vxr rear skirt fitted and has changed from the standard insert/valance to the vxr one give me an idea as to how they did it..
    Its just that i need to remove mine, for reasons i will reveal at a later time...
    Sunny Dartmoor
    Think once its on its on,no hang on someone's done it......
    Simon1 has done it,might be worth dropping him a pm........
    Regular Member cameraman's Avatar
    Leicester
    I fitted Spoons old VXR insert from the vxrd after he had the 888 touring car one fitted, all the clips had been cut off & it was a real ball-ache, I ripped the original out with ease but had to cut new tabs & soften the insert with a heat gun, took about 3 hours before I manged to pop it into place & had very sore fingers. Its only held in place by the VXR extension on the bumper & two cable ties, although you can't tell & its never moved since fitted
    Forum Moderator FIL 4822's Avatar
    Central England
    7 Post(s)
    Vehicle : Vectra VXR, VW Tiguan R-line Tech, Vivaro.
    Trim : Nav
    Engine : Various
    Year : 1 A.D
    Mileage : Rising
    Fitting it is very easy. It's only difficult if your bumper has the extra apron round it (xp kit). If it's an xp then be prepared for a wrestling match as they are a sod to get in place (square peg in a round hole springs to mind !) but they will go in..........eventually !
    Mine took about 45 mins, 3 blankets on the lawn to stop it getting scratched and the missus to hold the other end just to get the insert into the bumper, oh ! and 500 swear words a minute !
  1. How to remove and replace hazard light switch?
    By barry087 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 15:48
  2. Alternator remove/replace query
    By Paul_O in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2010, 20:18
