Results 1 to 10 of 11
Thread: limp mode+sort of usual problem 2.0dti
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default limp mode+sort of usual problem 2.0dti
    Had my first spanner light plus car to limp mode occurence today. Happened while overtaking up hill on the M25 after driving some 35 miles carried on for a few more miles to see if it would reset itself .
    noticed when under load car was leaving its own smoke screen .carried on for a few miles to see if it would clear itself but to no avail.
    Pulled into services switched engine off then back on again engine spooled up normally car has been fine all day also noticed since limp mode fuel consuption has improved usually 43-45 on a motorway run after occurence 50-52 has anyone any ideas as to what happened here.
    Full Member Big Sig's Avatar
    It may have just had a "moment". But I'd check all the hoses for leaks as thats normally the first failing on the 2.0 and 2.2 dti's. Its also very easy to check.
    South Wales
    yeah i had trouboe with limp mode on my 2.0dti, after several trips to the garage it was a split hose pipe in the engine, something to do with the turbo???? Sorry not mechanically minded, but it was a hose!!!
    Engine : 2.0DTi
    Mileage : 73350
    Cheers sean had a look this morning and found two connectors with splits ,Ordered replacement,s so hopefully all now will be cured .
    Engine : 2.0DTi
    Mileage : 73350
    Na wishful thinking, cars going from bad to worse keeps droping into limp mode even after changing connectors checked all the other hoses can not find any cracks or splits.
    Spanner light does not illuminate now when she fails but i do have a permanent exhaust gases warning light up .
    anyone got anymore suggestion,s
    Hertfordshire
    Going into limp mode under load is a classic sign of a gunged up boost sensor.
    Try having a read here.
    Engine : 2.0DTi
    Mileage : 73350
    been there and done that,
    still no cure car has eml light on permanently
    Had a look for the egr just to see if that was cruded up but if its on this car i cant find it .
    anyway just phoned stealers car going for a tech 2 this afternoon so i can ask some question s there
    i was supposed to be going away this weekend as well ho hum s**t happens
    Engine : 2.0DTi
    Mileage : 73350
    OK back from stealers had it tech 2ed engineer cleared all current fault codes
    what he listed was
    po234 sym 5b boost pressure sensor
    po110 sym07 intake air temp censor
    po638 throttle control circuit negative deviation
    po400 egr flow excessive
    po100 (air flow censor)
    po380 glow device circuit low voltage
    po105 sym03 boost pressure circuit low input
    now some of these codes are unrellated so can anyone decifer what the real problem is
    Portadown, N.I.
    Quote Originally Posted by bobssignum View Post
    The Egr is pretty easy to find, just follow the charge hose from the intercooler into the upper intake manifold. where the molding of the upper intake manifold bends downward, look just below and you will see a black round body a little larger than a D type battery, it should have a grey plastic cover on the left hand side of it, and has 2 coolant hoses going in to it, one from below, one from above. ( The EGR on the 2.0DTi's are different than the one in the EGR "how to" which I believe is off a CDTi )
    This is the EGR actuater, you can pry off the grey cover and see the little actuater mech' but to see if it is full of crud you need to take the EGR off.
    To remove the EGR you will need to remove the coolant hoses, undo the 2 torx bolts holding it on, and just wiggle it out. It does have a little rubber sealing ring that MAY have to be replaced, it didnt need it on mine though.
    Hope this helps,
    Tim
  1. 2.0DTI limp mode.. AGAIN!
    By The_Dutchman in forum Engine & Drivetrain
    Last Post: 20th June 2012, 21:49
  2. 2.0Dti went Bang then into Limp Mode
    By TonyP2020 in forum Engine & Drivetrain
    Last Post: 25th April 2011, 23:14
  3. 2.0DTI Engine Fault - Limp Home Mode Over 3000 RPM
    By coxstevuk1973 in forum Engine & Drivetrain
    Last Post: 4th March 2011, 17:03
  4. limp mode again and again and again stupid 2.0dti
    By barrymanalow87 in forum Diesel Engine related
    Last Post: 8th May 2010, 23:57
  5. Just got back..After limp mode saga..03 2.0dti
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2009, 15:04
