Results 1 to 10 of 18
Thread: Newbie with a few problems!
    Regular Member cmowen's Avatar
    Swansea
    Default Newbie with a few problems!
    Hi all,
    Am new here so please be gentle!
    I have just picked up an 02 Vectra 3.2 GSi with 50k, FVSH and 2 private owners. Its a lovely looking car in prestige blue.
    Couple of issues that I have discovered since purchasing:
    • Problem with the dash where all the dials drop and then come back to life, only with the TC light staying on. Restart and it goes away for a bit and then comes back? Reading the threads it would seem to fit into the CIM failure category, but am getting it checked into the local dealers for diagnosis.
    • Theres a really annoying clunk type sound which is intermittent and seems to be coming from the rear N/S door. Any ideas?
    • Also the car needs a service, its had two dealer services before so will probably get the service and belt / tensioners done when they check out the CIM problem. Does anyone have an indicative price for this work?
    Other than that its a great car, purchased at auction so no dealer assurance / warranty!
    Any help or advice offered greatly appreciated.
    Thanks,
    Chris.
    Full Member Big Sig's Avatar
    It does sound like the cim. Not sure about the clunk? so, service - £200, cim- £400, belts - £300
    Swansea
    Ouch, so the best part of £1k to get it all sorted, thats assuming the TECH2 doesnt flag anything else up!
    Sunny Dartmoor
    hope you get all youy problems sorted with minimal fuss......
    Pic's would be nice too,its the law around here m8,you'll learn......
    Swansea
    Hi,
    Will try and get some pics posted shortly...
    Just been to the dealers and they quoted the following:
    Interim Service - £185 or Full Service £205
    Will probably need plugs too £100
    £60 diagnostic charge to see what the dials problem is
    Does all that sound about right?
    I pointed out that the dials / TC problem is intermittent and may not be recorded to no avail.
    Are there any known specialists in South Wales (Swansea)?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi m8 and to vectra-c........
    hope you get it sorted out soon fella
    Jul 2006
    Mexico
    >The dials droping issue have to well known sources, the CIM allready mentioned and a faulty contact on the ABS plug.
    Unplug the ABS plug, make sure terminals are clean on both ends and replug. That cured my dials. Do this before you jump to the CIM which is a more expensive procedure.
    HTH
    Jun 2007
    Sittingbourne, Kent
    mate good choice of car hope you get all the problems sorted ...
    Meifod
    Thumbs up
    Had the same dial problem with my 3.2 GSI,my local dealer was stumped !,after numerous visits to them they finally decided it was the ECU !,this was after changing the air flow meter,various Tech 2 attempts.Cant complain though,because even though the car was well out of warranty by 8 months it was all sorted free of charge,and since then has been utterly reliable.They restored my faith in Vauxhall.The dealer was Arthurs of Oswestry.
    Hope you get yours sorted soon.
    Swansea
    Thanks for the replies. I took a look at the abs plug earlier, there appeared to be a small amount of grease over the connections. A quick brush seemed to clean them up so watch this space.
    djveccy, I doubt I will be as lucky as you with the bill if its the ECU!!
  1. Hi...Newbie with questions/problems already
    By lee_thefirst in forum Introduce yourself.
    Last Post: 6th November 2012, 23:18
  2. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  3. hi everybody. Newbie with problems.
    By sandy white in forum Introduce yourself.
    Last Post: 28th June 2011, 21:53
  4. GSI 3.2 newbie with problems !
    By djveccy in forum Introduce yourself.
    Last Post: 30th June 2008, 14:18
  5. Vectra-c newbie with serious problems!!!Advice needed
    By slyneely in forum Northern Ireland (RO - Vacant)
    Last Post: 20th May 2008, 18:32
