Results 1 to 10 of 11
Thread: Gear stick has started going pop!!
    scotland
    Angry Gear stick has started going pop!!
    Hi Guys,
    Recently my gear stick has started making a popping noise every time i push down on it. I notice it everytime I change gear!!!!!!!!!!!!!!!!
    Really annoying, should this be a warranty job or will I have to pay out for a new one. I think its just the glue on the head of the gear knob is now loose and it has room to move. Really irritated by it.its a march 2006 motor 1.9cdti with just shy of 50k on it. I know its high miles but I had a cavalier for 6 years(J reg 1.8 4 pot sohc carb engine) and the fundamental stuff never went wrong like the Bleeding gear knob!!
    Any ideas?
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i would have thought they would do it under warranty you are still in the conditions of a warranty!! it wont hurt to take it down and see what they say
    Kent
    My dealer said that the gear knob isn't under warranty because it is afacia item not a mechanical item. My dealer hamered mine back on and CRACKED THE TOP really ****ed me off. Get some glue and stick it on mate, thats the easiest thing to do.
    Feb 2007
    the chrome window strips arent mechanical but people have had them changed on their warranty i would still go down i wouldnt be happy with that
    scotland
    I think I`d be forced to beat the mechanics head back on with a hammer if they try that crap with my motor.
    I`ll head down and see them next week. Really good vx dealers I use actually.
    They have done a couple of warranty fixes for me and have been really helpful.
    sheffield
    Default dodgy knob!
    Hi Mate mine did exact same it will get worse and worse so just give it a good put or tap it slightly from underneath and it will come off its just sat on a splined shaft.
    10p worth of blue tack and bash it back on, hot had any more bother with mine since!
    Pete Mc
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    Quote Originally Posted by oxenburger View Post
    Hi Guys,
    mine is doing the same, also get a strange noise on my driver door, I rest my elbow near the glass, & when I take my elbow off the door it makes a noise!....I was going to put up with it but may pop to the stealers later in the week now....
    Regular Member Karl's Avatar
    Sunderland
    good excuse to buy an irmy gearknob
    Full Member VectraMat's Avatar
    Hull
    Mine started doing this but i just put up with it, until it came off in my hand at 50mph!!!! So i did as above and got some high strength glue and stuck it back on, problem solved.
    VXR Gone - Now in BMW 320cd M Sport Convertible
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    As above, trim only covered in the first year of warranty, if you have a very good relationship with your dealer they may try wiggling it for you but unlikely they will be successful.
    I just stuck mine back on with a thump after it came off in my hand and it been fine ever since. Adding blutack as Pete says sounds like a good idea.
  1. Where can I get this gear stick?
    By John LE in forum Styling
    Last Post: 30th April 2012, 14:14
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. any one got an old gear stick ?
    By Lump in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 11:41
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
