Results 1 to 10 of 14
Thread: Help please
    Regular Member Jay Kay 313's Avatar
    Burgess Hill
    Default Help please
    Ok I know it's a Vec B, but i've got a problem with it has a missfire
    It is a Z18XE engine and thrown up 2 fault's on the Snap-on scanner
    1) on injector number 2 open circuit
    2) Missfire on cylinder 4
    I've checked the the plug's there fine and replaced numbr 2 injector + all injector seal's. went on raod test was going fine, turned around and on the way back the EML came back on and started missfiring again and showing the same fault
    Is there something I'm missing??? or try next???
    Thank's Jay
    Burgess Hill
    Oh it's a 2001 if that help's
    Maida Vale
    Coil pack faulty....?
    Burgess Hill
    Possable, I could try swapping it over with my old vec B when I get it back as my dad's got it at the moment cos it's his vec that has the missfire.
    Thank's Thomas
    You sure its a z18xe and not an x18xe/1?
    Burgess Hill
    Yeah mine is the X18XE1 and his is the Z18XE with the missfire
    The coil packs may be different then. But I agree with the above, start with the coil pack
    Burgess Hill
    the engines both look the same, the only two things that I can see thats differant is the throttle body and the Cat is mounted at the front under the exhurst manifold, The coil pack looks the same so fingers crossed
    Pretty sure the extra cat is so its euro4 and not euro3 - no problems there. The TB's are different as the x18 is cable throttle and the Z18 is fly by wire. Hopefully, nearly everything else is the same
    Burgess Hill
    Thats cool I'll give it a go thanks for the info and I will let you know if it works
