Results 1 to 10 of 14
Thread: Auto headlights - sensitivity
    May 2007
    Cheshire
    Default Auto headlights - sensitivity
    Is there any way of changing the sensitivity of auto headlights ?
    IMO, they are far too sensitive, staying on during the day in anything but bright sunlight.
    Jul 2006
    I think the short answer is no.
    I use the Mk 1 eyeball
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    His short answer of 'no' is correct, i bet you've had the windscreen changed at some point havent you?
    May 2007
    Cheshire
    Plasma - thanks for your post. The windscreen had to be changed within a couple of weeks of getting the car - so I dont really know what the auto lights were really like before.
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    best bet is to find another member near you with auto-lights and then you can compare in the same conditions
    May 2007
    south ockendon
    mine dont switch on at all during the day unless i go through a longish tunnel
    even then they switch off 10 seconds after coming out of it
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    gelpack could be dirty, not aligned correctly after the new windscreen fitted..
    Winteringham
    mine stay on most of the day as well but don't know if screen has been changed, is there any way of the stealer's readjusting them????
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Quote Originally Posted by pyro_maniac View Post
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by carteg View Post
    as a test. if you remove the sensor with the engine on/auto lights on and let it hang carefully.. if the lights go out after about 10 secs or so this is pointing to the gelpack being misty and/or the sensor not aligned correctly with the windscreen.. This is how i tested mine to see if mine was faulty or not and it wasnt!
  1. Auto Wipers and Auto Headlights
    By skip85 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 01:12
  2. auto wipers, can you fit auto headlights?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2011, 11:32
  3. Auto Headlight Sensitivity
    By FatboySteve in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 16:24
  4. Auto headlights
    By G.O'Rilla in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 21:54
  5. Auto Dip Mirror sensitivity
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2007, 22:16
