Thread: 1.8 problems
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default 1.8 problems
    ive been having some problems now for quite some time my emission light has been on and on tech tests which are costing me 65 quid a go are coming back with no codes. now on occasions ive had the car with the spanner through it. the first time this came on it made a strange noise when i tried to start it up, so i turned it back off and started it again. this time it started and it drove home with no power what so ever and wouldnt go over 4000 rpm. well last night the same thing happened on start up turned it off and spanner light went out drove ok but emission light is back on.
    the revs are not ok it trys to stall always first thing in the morning and sometimes when its been left standing a while the revs bob up and down and there is no power put foot down in first when releasing the clutch and the revs drop right down almost like a turbo lag i know its different cus when i used to put foot hard down i would have wheels spinning ive cleeaned the throttle body but really want it sorted now dealers think it might be the ecu. could an ecu cause all these problems
    please help me guys i would appreciate it
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    i see ive had a few looks and ive posted loads of threads with problems why isnt anyone replying to any is it because i said i was gonna get a mondeo at least there reliable
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    I can't understand why a code isn't stored mate. Mine was on the other week, occassionally I put my foot down and the car started missfiring, emmissions light came on. Vx said it was a missfire fault, faulty coil pack or spark plug, well I changed both and it has been fine since! But mine stored a code. Is your light on all the time?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    it comes and goes now its on all the time dealer has reset it and ive had spanner light show twice the first time was limp home mode and the other time i just switched it off and turned it on and the fault went
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Check all the simple things mate, Earth strap, plugs even air and fuel filter. Have you had the MAF unplugged? Check all conections ect. Is your TB fly by wire or cable operated?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    well got the car back from the dealers and they have recommended a new ecu the only fault code present was po170 fule trim bank 1 running rich hence the bad fuel consumption, also the other problem found was the flexi down pipe it is split to get this all sorted ive been quoted 800 bags looks like some saving has to happen to get it sorted.
    good news for all 1.8 owners if they have a spare 4000 pound regal do an engine turbo conversion for the z18xe and it roughly puts out 230 bhp
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
