Thread: electronic warning light
    Leeds
    Default electronic warning light
    I've just swapped the cd30 for a kenwood headunit n now the electronic warning is perm illuminated. Any ideas?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Do you mean a warning light on the dash?,if so could you describe it please,it might help in sorting the problem.
    Leeds
    Yes its on the dash, in the middle between the rev counter and the speed. Looks like a car with a spanner through the middle. Had a look in the cars manual and it says this is the 'engine electronics' warning light. I can't imagine swapping the standard head unit for a different one would cause this......
    11 Post(s)
    Quote Originally Posted by petersaxon View Post
    Isn't the factory fit stereo wired into the alarm somehow? Used to be on my previous Vectra-B (yes, I know probably completely difference), but maybe you need to earth a wire in the iso connector somewhere to simulate the original headunit is still in place.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If the stereo was a straight plug in swap it shouldn't put the light on,try disconnecting the battery for 1/2 hr,you'll have to reset the windows afterwards (ign on and put to fully up until you here a faint click then the same in the lowered position), it could just be being temperamental.
    Full Member Big Sig's Avatar
    Do you not need to tech-2 the old unit out? With the full canbus cars the car's ecu's would be expecting to see the stereo thats now gone??? Could that be it?
    Leeds
    Ok change of story.....
    I've had the AA out to save me the cost of taking it to the garage to find out what fault code is showing as ;-) anyway... Its the airflow meter... Now this is to much of a coincidence as on Saturday I did the air filter mod and took that piece of plastic out to allow more air to flow..... anyone else experienced this? The AA have reset the warning and I've been for a little drive and it hasn't come back on, but do we reckon it will come back on again soon?
    Cheers,
    Pete
    Only time will tell mate. Fingers crossed, it will not come back. But if it does, you know what to change
  1. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  2. Odd never seen before warning light
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 14th May 2011, 10:33
  3. Electronic Warning Light after Engine rebuild
    By Shaw in forum Engine & Drivetrain
    Last Post: 6th March 2011, 17:04
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
electronic warning light on vauxhall vectra c
electric warning light vectra c
